drip
hi randy, put the keel up, you will have less keel cable exposed to the water and less torque on the mounting hardware caused by the rocking of the boat acting on the arm of the keel. as for leaks, have someone steer while you look for the inflow. look at the keel lock down bolt area, it is above water line but sloshing can leak through the threads. catalina tells us to keep the threads gloped with grease. find the leak befor greasing so you will know for sure john
