..well this happened this weekend. On survey I knew the rudder was saturated. And after struggling with removing the rudder in the fall, curiosity got the better and I started to tackle the investigation.
I was able to confirm the rudder as straight thanks to laser level and a new set of V-Blocks. I cut the shell in half with oscillating tool. Honestly I thought I made a huge mistake while cutting because everything "appeared to have dried out". Once I had the rudder fully apart, I felt vindicated as there is plenty of water inside.
Was there a previous repair? Looks like a spray foam (open cell nonetheless) repair was made. Everything is now out. While I am trying to contact Foss for rebuild quotes I will carry on until then. Spring is just around the corner
What kind of foam has anyone on the site used for this repair? Any helpful hints in maintaining the rudder profile and rebuilding fair and straight?
Saillife and Boatworks used epoxy foam. I think that is the course. Also plan to leave a large trough for some SikaFlex or 4200 at the shaft/rudder interface to prevent water intrusion in the future.
