Chainplate Rebedding 101 - with Bed It with Butyl from Maine Sail
I am just guessing that (hopefully) the chainplate also connects into some part of the structure...but also”sealed” to the deck by the flange.As you can see in the link I provided, my chainplates move THROUGH the deck and are connected to tie rods down below that connect to the hull and supporting superstructure down below. The deck does not carry the load at all.
I am not an expert on chainplate design, and can only speak from my own experience. That said, it certainly seems odd that the chainplate itself appears to be welded to the deck cover plate, which means that all the load is imposed on the six bolts and that the deck would then have to carry the load.
Do you have any photos of what is underneath?
Do any of you with the same boat have this design?
