Rounding Up
Andy,I find that my 320 also has a strong tendency to round up when heeled substantially. Maybe you know this, but I have found that using the traveller to reduce power on the main is a must -- seemingly more so than on other boats that I've sailed. While letting out the mainsheet will spill wind, the fullness of the large main works against you. Early use of the traveller will keep the main tight as you drop it to leeward. Don't worry if the jib backwinds the main a bit. You might also experiment with letting out the jib more, and/or rolling it in a bit if you have a larger genoa. In 25 knots true (common on SF Bay), I sail well balanced with one reef, and a 100% working jib.Also, avoid sailing broadside to incoming swells. This will tend to heel the boat, unbalance the hull, and round up.What you're describing is no fun, for you or for white-knuckled passengers. Once you learn to deal with this trait, the 320 sails great. Hope this helps.
