I recently acquired a c 27 and went out this weekend to do some conditioning work.
The interior took lemon oil pretty well so I then went to the exterior.
The cockpit coaming
took a sanding well to remove the peeling varnish then I oiled it and was planning on hitting it with more oil then varnish...
however the other one is in really bad shape and already repaired once.
Does anyone know of a source for these in teak? Any other wood options? I have seen the white plastic replacements for them on Catalina Direct but would like to keep the wood accent if possible.
Thanks in advance
The cockpit coaming
Thanks in advance
