Hello forum!
I have a C-25, and I am in the process of refinishing the crib boards and trim. The two vertical pieces of trim the crib boards slide/drop into are where I am stuck. I have removed the screws from the inside, and I suspect they are glued/sealed with mastic. Before I started to really try and pry them off, I wanted to make sure they didnt have screws through from the cockpit also that have been countersunk and plugged. The varnish is too thick to see the wood grain to tell. Thank you in advance, Mike
