C- 22 NEED HELP WITH HULL ID#
May 1, 2016
7
catalina 22,macgregor 22 Havana IL
Have a full keel c-22 i would love to know for sure what year it is this is all the info I have interior id plate c-22 sn 11575--outside scratched in is ctyh157583f no title or registration card at all
Sep 14, 2014
1,294
Catalina 22 Pensacola, Florida
Hull serial number is 11575, built in 1983 f is month code, not sure which one.
May 1, 2016
7
THANK YOU MUCH!!!!!! Am not sure if they have it right on the rear on the f location it's just scratched in there
Sep 14, 2014
1,294
By the way it is supposed to have 12 numbers and letters in total so might check and make sure you have them all. Format is CTYH then last 4 serial numbers from serial number plate inside cockpit transom then a letter 2 year numbers and a letter. see pix of hull serial number plate in inside of transom from my 83 below. And the pix of the HIN on the hull. Translation of mine is CTYH1607M83F
May 1, 2016
7
Thanks so much for your help my rear sn looks like it was scratched in with a nail. I am just going to part the old girl out she has had no care at all for the last 10 years loads of water damage
Sep 14, 2014
1,294
Ok , if you part out , do you have any decent cushions? I need the one for port side over the table when lowered for sleeping. Could also use spare jib/genoa cars for a 15/16 inch track. Do you have a stern pulpit (railing)?
