A Few Points on C30
I just bought an '81 C30, and am very happy with the boat. I certainly agree with everyone who's recommended a surveyor -- not just of the hull, but separate ones of the rigging and engine. If you can, be there to watch and learn -- my surveyor had a lot of very helpful hints.That said, here's a couple of things I'd watch for and talk to your surveyor about:* Check the deck immediately under the mast to see if it is compressed. It's quite common for the deck to be deflected 1/4" to 1/2"; Practical Sailor magazine says that they found the condition in almost every C30 they looked at. The compression itself isn't a deal killer, but beware of any cracking in the deck or in the hull liner around the compression post in the cabin -- that indicates more serious problems. Catalina has a great sheet on how this repair can be done -- I haven't had it done yet (mine's compressed about 1/4" or so) but I've spoken to some owners who have who say it's not too bad.* Along the same lines, pull up the cabin sole (the wooden hatch in the deck of the cabin) and check the wooden block at the very front of the bilge, under the compression post. You want to make sure it's not rotted out. Also check along the bilge by the keel bolts to see if the wooden liner is exposed (if the fiberglass has been worn away or damaged) and is soft/rotten. These are more serious problems that need to be addressed.* Make sure your surveyor checks out the steering linkages if the boat has wheel steering -- mine didn't, and less than a month after I bought the boat it broke, luckily at the dock. Also check the throttle and gearshift linkages for the same reason. And make sure the boat has, and you know how to use, an emergency tiller in case you have the same problem.These are just some high points to have your surveyor cover with you -- s/'ll have plenty of others you won't have thought of. I bought my boat knowing about the mast deflection and some softness in the lower mast step in the bilge and used those as bargaining tools in negotiating a price. The yard that did some work on the engine prior to closing the deal also found some problems with the prop shaft needing to be straightened, which also led to some price adjustments.Good luck!Mike TurnerS/V AmityLong Beach
