Leverage
Hi Dave,Hope you are enjoying the new boat - obviously you are getting out enough to find room for improvement.Like you, I wanted to shorten the tiller - until I got into my first storm. You can shave 6 inches off the tiller and it will still work, but I found that in heavy winds, the extra leverage on the tip of the tiller makes steering more comfortable.I am a relatively big guy, so wrestling the tiller is not a problem. I just like the comfort of easy steering in high winds. In normal wind conditions, I just keep the tiller in a semi-raised position, which gives people more room. When tacking, I raise it while coming through the wind, then bring it back down. When I have experienced sailors aboard, I sometimes steer from the low side.Best of Luck, and let us know how you make out!Rob
