I have a stubborn hatch that continues to leak even though I re-bedded it twice (with Life Caulk). I think the problem is that the coach roof is slightly curved at that location and the bedding compound doesn't get a good continuous seal. I bought some butyl tape from you, and wanted to give that a try. It is a small hatch about 1 ft. by 10 in.
The Lewmar hatches have a channel in the middle, so I wanted your advice on the best way to lay down the butyl tape for a good seal. Do I use three pieces (each side plus one in the middle) or is this too much? Any special trick for hatches?
Thanks.
Thanks.
