I've read through Mainesail's primer on bedding gear with butyl. Am convinced that's a great way to go for many applications. One nice thing is that it seals right away since it has no cure time. But it is recommended to tighten the fasteners over a several day (or longer) period. Keeping that in mind, can butyl rubber be used in applications where the fasteners doesn't penetrate the hull or deck? For example, on our Catalina 30 some cabin-top hardware (deck organizers, winches, etc.) is anchored by nuts embedded in the core. If you tighten these bolts over a number of days won't the seal between the BR and the bolt be broken?
