Butyl rubber to seal screws?
Nov 15, 2014
137
Catalina 30T 5830 Green Bay
I've read through Mainesail's primer on bedding gear with butyl. Am convinced that's a great way to go for many applications. One nice thing is that it seals right away since it has no cure time. But it is recommended to tighten the fasteners over a several day (or longer) period. Keeping that in mind, can butyl rubber be used in applications where the fasteners doesn't penetrate the hull or deck? For example, on our Catalina 30 some cabin-top hardware (deck organizers, winches, etc.) is anchored by nuts embedded in the core. If you tighten these bolts over a number of days won't the seal between the BR and the bolt be broken?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
only if you over tighten its one of those things that you need to know when to stop cranking down on the bolt or nut
11,756
It can work but I would advise body weight to aid in "setting" the butyl. Get a solid 200+ pounder to stand on the winch while you snug it..
Bed-It Tape does not change consistency so waiting to tighten is different than it is with a "curing sealant".... You are merely waiting for it to "displace" not cure...
If you make the butyl cones slightly longer on the machine screw this helps with screw sets.... Keep in mind this works with Bed-It Tape and I certainly can not guarantee success with butyl tapes not specifically formulated for bedding deck hardware as there are major variations and literally hundreds of formulations.
Nov 15, 2014
137
OK - I did just get 2 rolls of Bed-it Tape. Was hoping to do this today but high temp is only going to be about 45 deg. Too cool??
Please clarify - in a thru bolt situation w/Bed-it Tape, ideally only the nut is turned, correct?
With my winches and DOs, I won't be able [necessarily] to put the bolt through the base and build the cone around it - when I put the bolt in the hole it will get pushed up when it gets to the nut.
In these cases, how does turning the bolt several times to tighten affect how the tape "binds" to it?
Thanks!
11,756
Not too cool it just slows the displacement...
In an "ideal" situation yes. Sadly placing metal bits into decks and threading into them is not "ideal" but rather it is what it is so we make do and it can work...
This will require two people one to hold the winch and one to snug the bolts. Again deck inserts are not ideal but they save production money....
Thanks!
If done properly if works fine but it is a bit tricky due to the inserts.... If in doubt a marine sealant such as Sika 295UV can be used instead...
