Hi guys.... After smelling a burning smell through the airconditioning vents, I found this ugly scene under the panels on a factory installed A/C. As you may see, the ac common has separated from its lug on the circuit board. I think this burn has gone on for a while. We smelled the burning ,thinking this was " dust" burning off while running the heat for the first time after the spring splash. Some of the guys at the marina seem to think this is the result of an overload over time witnessed by melted insulation on the surrounding wires further down from the terminal strip. Or maybe a bad crimp job?? This airconditioner is dedicated to its own supply from a second shore power inlet. I have read the many posts from Stu and Maine regarding bad connections. I have a new circuit board in hand, but would like some opinions. If this was the result of overload, why wouldnt the 30 amp breaker open? Thx in advance. Now for the nasty pics....
