caguy .... I like your thinking ...
Spelling out "SailBoatowners.com" may not be conventional, but I still like it. I don't know why but I'm not crazy about "SBO" for some reason (but if you did use the 3 letters, why not make them vertical along the left edge.SBOI like the idea of #3 but it looks funny to have the sailboat sailing downhill. With the triangular burgee, it is difficult to incorporate that idea.What I like most is the way #2 stands out. I think the blue swoosh on the white background is very nice, so I have a further suggestion utilizing the layout of #2.I think the red that is in the heading of this forum is very attractive. I would make the white background a band that goes across the middle of the burgee. Then have the upper third and the lower third a red field. In the upper field at the left corner, put a white sail or sailboat emblem. The one that you are showing may be a little too busy so maybe that should be simplified so it pops out more nicely. Something like the Kona Kai YC emblem would work well.caguy, you made some nice drawings ... could you do my suggestion?
