I just bought a 1987 C22 in September and the PO didn't repair the leaks in the upper shroud deck fittings. Now the main bulkhead on the port side needs replacing because of delamination. (I also want to add a storage cupboard area over the sink while providing some measure of privacy for the head).It doesn't appear to be that difficult because aside from the upper shroud bolts, the rest is just screwed into the fiberglass sink area with wood screws.My question is, should the paneling/bulkheads be marine grade plywood, or is jsut common 1/2" acceptable?Thanks~Bilbo
