Bulging fuel tank
Jun 2, 2015
5
Hunter 41ac Penetang
I have just over filled the boats fuel tank . Now the tank has raised the aft cabin bed panels. . Believe the vent line is loaded but it is higher then fill cap . Is this going to cause engine problems , air lock. New boat first time filling
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
NO
But don't make that mistake again because could put too much pressure on tank and how it is mounted in place but should no cause any problems running engine.
But also when heeling could spill fuel out vent which has happened to me and did not over fill like you did.
Nick
Dec 14, 2003
1,442
It will not cause problems running the engine but if need to bring those panels down before you burn enough fuel, just siphon or pump some fuel off into a jerrycan through the fuel intake.
Jun 2, 2015
5
Re: NO
Thanks for the info, not sure heeling over would spill? large loop in vent line at vent opening. Will be motoring this weekend. Should level out after few hours!
Sep 20, 2006
2,952
Which marina are you in Penetang. We were at BayMoorings for 8 years and just moved up to Parry Sound this May. Did you buy White Pines by chance? Saw it for sale for a while.
Jun 2, 2015
5
No not white pine, I'm also from bay moorings, owner of Kokomo 33.5 and New owner of 41 also . Sorry to hear you are in parry sound. Will be in Penetang sometime after the long weekend with the. 41 not sure of new name yet . See you in the sound this summer
Sep 20, 2006
2,952
Are you Scott ?
