Buffing Our Scratches In Stainless Steel
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
I discovered a nice rough gouge in the bow pulpit.
Can this be buffed out and made smooth again?
Thanks
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Thanks
yes it can..... but it is a lot of work and sanding ...you have to sand it with several grits starting from the course to the finest ...then use a compund for polishing ss....polishing is the art of making large scratches small enough that you cant detect them with the necked eye ...when you get them to that point take a magnafier and look at the scratches you cant see with the eye alone you will be amazed at what you see....
regards
woody
RichH
Feb 14, 2005
4,773
Standard 'industrial' finishing of stainless steel is to flat-sand with progressively finer and finer grit
eg. 80 ---> 120 ---> 180 ----> 220 ----> 320 grit (to remove all scratches from the previous grade of grit), then buff with 'tripoli' (a white 'rouge' that contains crushed 'diatomaceous earth / DE', .... sometimes known/named as "kieselguhr")
