Bubbles in hot water
JoeK
Beneteau 34 Oxford, md
After recommissioning my fresh water system this year, my hot water is filled with tiny bubbles. Not the cold, just the hot. I have flushed many gallons of water through the water heater. I don't suppose it is harmful, just unappealing. Any ideas what might cause this and how to fix it?
Aug 19, 2021
511
Hunter 280 White House Cove Marina
Do the bubbles disappear as you let the water tun?
If they do, you could have small leak. As water escapes air enters the pipe or piping of the hot water system.
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
Bubbles may come from your Shore Water supply.
Chlorine or Sulphur gases are most common.
Jim...
Jan 7, 2011
5,858
Oday 322 East Chicago, IN
Jim...
Strange though that is only the hot water…
Unless the heat is causing something in the water to vaporize and cause the bubbles.
Greg
Feb 10, 2004
4,184
Hunter 40.5 Warwick, RI
When water is heated, the heat drives dissolved oxygen out of the water. I am told that this is why in freezing temperatures, a hot water line will freeze before a cold line next to it.
Maybe your water supply has a great deal of dissolved oxygen in it?
Does the water have an odor?
A really long shot suggestion, there may be air trapped in the top of the water heater. Try releasing some pressure with the pressure relief valve. There's a lever on the valve, if you lift it some water, steam, air will come out. Be careful it will be scalding hot. There should be a hose attached directing the outflow to the bilge.
JoeK
Update/clarification. The bubbly water is not "hot". The engine and electric are off. It is just what comes from the "hot" side. It is cool water
Apr 1, 2004
183
Catalina 34 Herring Bay Chesapeake, MD
When you winterized was there a chance that any antifreeze found its way into the water heater. If so will take a few additional flushes of water system to elevate the issue
Likes: DaveJ
JamesG161
Feb 14, 2014
7,935
This is a big clue.
If it is dissolve gases,
1) turn off water pump and open all hot water valves.
2) Let that sit for a while, say 30 minutes.
3) Close the valves, then start your water pump.
If bubble still there, then it is a air leak on you water pump suction.
If not, it was dissolved gases.
Jim...
Dec 28, 2015
1,923
Yea I think your physics is off a little. Hot water will freeze faster than cold water when exposed atmosphere ( not in pipes) due to its ability to vaporize more readily due to it’s temperature (increased vapor pressure) by vaporizing, it realeases its fast moving molecules ( heat) and leaves the slow ( cold) allowing it drop temperature and freeze in a shorter time than cold water. This is dependent on surface area and commonly demonstrated by throwing both into very cold air.
Nov 6, 2006
10,151
Sometimes, the bubbles are caused by the anode rod being corroded.. ya may need to replace the anode in the tank.
