Brooks & Gatehouse VHF
Brent Headberg
My Hunter 33.5 was equipped with B&G Instruments including a flush mount B&G VHF at the helm. Just recently my transmit signal has become garbled and is sending chirping sounds after a few seconds of clear voice transmission. Does anybody know if this could be a problem with my mast-top antenna? I've checked all other connections, including a new plug on the Mic and they appear dry and no corrosion. Any help in trouble shooting this is appreciated. Capn' Brent S/V Elena Lua http://www.elenalua.homestead.com
E
Ed Schenck
Battery connection.
A low voltage or poor connection will cause that. It takes quite a few more amps to transmit. Your house batteries are probably fine but a bad radio ground or corrosion in hot lead will do that. I also carry one of those cheap rail mount antennas as a backup. You could try that to eliminate the mast antenna as the problem.
Don
I'd bet Ed is correct
You might notice the same garble when listening to someone using a handheld immediately prior to their battery going dead. I have a B
