Veridgris - the green crap that forms on bronze
Verdigris is the 'green' that forms on bronze, it is copper acetate - an oxidation of the copper with acetic acid (in seawater). Verdigris is slightly soluble in ethyl alcohol ... and not much else! you need to mechannically (sand/buff) remove most verdigris as there simply are NO magic solutions to cleaning BRONZE (without pulling either the tin or the copper out of the bronze). The 'ancients' used a mixture of fine pumice, salt, beeswax, olive oil, wine, and lemon juice to 'burnish' their bronze and to keep it clean and affect some protection. The pumice for abrasion; the beeswax and olive oil to offer protection and retard oxidation, the salt, wine and lemon juice to aid in removing the 'green'. For bronze that I want to turn a rich brown ... I burnish (fine sanding then machine polish with jewelers rouge) .... then apply rub in a paste of beeswax and olive oil several times (like 'seasoning' an iron fry pan ... and you can accelerate the 'seasoning' by putting the part (with the wax and oil mixture on it) in an oven for 300 degrees for several hours).For bronze that has been bright polished ---- (sanded @ 400-1000 grit), then machine buffed with *jewelers rouge*, etc.) I spray (spray can) on many successive coats of *exterior grade* clear polyurethane. If you are using one of the 'modern' two part acrylic-urethanes (Honey Teak, etc.) for your brightwork ... the clear overcoat is BEST for polished bronze and if applied 'thick' will last MANY years for exterior bronze; then polish the urethane lightly with 3M Finese-it / 3M Perfect-it to get the urethane FLAT and glossy. If you want your bronze to be shiney and good looking, the fastest and best way is to burnish/polish with high speed fabric wheels onto which you apply jewelers rouge (buy it in a hardware store). You can forget about most BRASS cleaners/polishes as they simply will not work on BRONZE.
