I have a 1994 Hunter 29.5 with a broken thru hull vent(I think it is a vent). enclosed are a few pics. It is located on the port side near the stern. the outside part broke off and is on the bottom. I noticed it was broken as I was leaving the boat and took the inside part off to get measurements to order the part and did not trace where the hose went. I am assuming it goes to either the holding tank or the fuel tank. The boat is 1 1/2 hours away and I was hoping to have the part when I go back. I have talked with Hunter and they are having a hard time finding one that fits the hole in the hull. The measurements in the pics are larger than all the fittings I have been able to find. The part no. in the owner's manual is PL0520 but I have not been able to find that number. The fitting next to it has a 90 degree fitting on the inside of the hull but this one is straight. Does anyone have a part no. and does the outside look like the other vent?
