broken steering rod. Hunter 310
4
hunter 310 Koudum
The connection rod between my edson steering column and the rudder is broken. I checked all edson catalogs but cannot find replacement parts.
Is there any experience in soving this.
thanks in advance. Peter
May 24, 2004
7,175
CC 30 South Florida
Try contacting Tech Support. You may also try contacting a Tool and Die shop in your vicinity to see if the part can be repaired.
Sep 10, 2012
4
hunter 310 Koudum
Benny, I took your advice and it wordked out for me. Great support from the tech support people at Hunter and Edson. Thanks for the advice.
Peter
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Great
Glad to hear you got good support from Hunter and I always also have had great help from Hunter,are you repairing the part or replacement.
Nick
Sep 10, 2012
4
hunter 310 Koudum
Nick
Nick,
They were indeed very helpfull, and so was Edson. I'm waiting for delivery and we will replace the parts as soon as they come. I want to sail!!
Peter
harv
May 24, 2005
45
-Hunter -310 Forked River NJ
Hi
Could you tell us H310 owners where along the rod did it breaK? Any idea why it broke? Was the rod lubricated?
Sep 10, 2012
4
hunter 310 Koudum
Hi
Sorry it took me so long to answer.
It was the connection to the rod on the rudder side that broke. Bad maintenance is what caused it. I just recently bought the boat from the previous owner who was not too keen on maintenance.
regards, Peter
harv
May 24, 2005
45
Sterring system problem
regards, Peter
Thanks for the reply- I assume you are talking about the lubricating the zerk fitting on the rudder quadrant. But how do you get to the zerk fitting at the base of the Edson pedestal, inside the larger fiberglas pedestal? Can't reach down to the base from the top of the fiberglas pedestal.
Can you get to it by taking up the rear deck and lubricating it with a lube gun that has a bendable hose fitting?
