Interesting Faucet Repair Alternative.
A friend of mine suggested an interesting alternative for repairing the stock H260 fresh water faucet.Rather then replace the faucet or purchase the same poor quality check valve, he suggested attaching a small 5/8" hose on the threaded end of the standard faucet. Then connect a standard "West Marine" 5/8" check valve (about $6.00 per unit), then more 5/8" hose into a 5/8" to 1/2" reduction fitting and then the 1/2" end should fit into the water lines on the H260.I like this idea a lot because first, its pretty inexpensive, second, the standard faucets are really not too bad, its just the plastic check valve, thats a part of the faucet, that is subject to freezing and cracking. Thirdly, when winterizing the boat, rather than disconnecting the water line up by the faucet (which is a difficult location), I will leave about 12 to 14 inches between the faucet and the check valve. The new check valve will be in a better and easier location to be removed and to blow out the water line.
