The aft two pop-top support poles on my '83 C25 have come loose at the pop-top. The heads of three of the four screws have broke off (after years of sailing with the pop-top up), leaving the screws themselves solidly screwed into the pop-top. No "extractor" is going to remove these babies. I was able to remove the one that did not break. It is a #10/24, 1" long SS screw.What I want to do is install new screws just a little bit forward of the existing ones. I will drill a #25/3.8 mm pilot hole 1' deep, and then use a tap and die to rethread the metal (SS) plate which appears to be sandwiched under the fiberglass of the pop-top.Because the new support-bracket position is going to change, I will have to redrill a new 5/16" hole just below the existing hole at the top of each support pole, and then cut off about 1/2" of the top of each pole --so it still clears the bracket when the top is going up or coming down.I want to do this only on the aft two support poles, as the forward ones appear to be in good shape. I'm thinking that this will leave the whole pop-top sloped just a bit aft, but that the pop-top "lock" on the mast will still work.My questions are: Is this the best way to fix this problem? Is there a better (easier), way? What if anything do I put on the new screws before I screw them in?
