Broken Isolated mast foot on a Hunter 26
Feb 3, 2019
4
Hunter 26 Lake Coeur d'Alene
I had a mishap when lowering my mast on my 1995 Hunter 26 and broke the Mast foot and have had no luck finding a replacement part on the web. Can anybody tell me where I can find this part? I have included photos. Any help in turning my boat into a sailboat again would be appreciated.
Thanks
Aaron
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
The store here on this site may have it or try RigRite. I wonder if a weld shop could fix it?
Actually I know first hand that the store on this site has it. I broke mine three summers ago and they had a new foot out in less than a week. Here is the one I broke. YOu can see the "ears" broke off.
Apr 27, 2010
1,279
You may want to use 4 or 5 aluminum pop rivets to attach the extrusion to the new foot. They seem to hold properly for the forces involved in stepping or removing the mast, for my 23 at least. And if you manage to sway the mast sideways the rivets are likely to sacrifice, avoiding damage to the mast or foot. I have had that happen and the rivets broke and only did minor damage to the mast extrusion that was easy to bend back.
Feb 3, 2019
4
good advise, I also plan to run a line on both sides of the mast to keep it from swaying sideways when stepping or removing the mast.
thanks
thanks
Whoa! That might be the issue. The H26 came with "baby stays" that are used when stepping the mast. When I broke my mast foot, I also bent the gin pole and bent the connector of
ne of the baby stays so I have experience making new ones (if you need it).
Feb 3, 2019
4
My gin pole is fine but when I bought the boat used, it didn't come with baby stays to keep the mast from swaying sideways when stepping or removing the mast. If you have advice on how to build baby stays that would be great.
On my mast, there are small holes that the baby stays "clip" into. The end of the stay has a hook (see picture in previous post). I used stainless steel cable from Tractor Supply, along SS wire nuts to secure the hook on the mast end. The other end of the baby stay connects to a metal loop at the base of the mid-ship stanchions. I secured them using a SS bail and SS wire nuts to create a loop at the end of the stay and then simply shackled the stay to the stanchion base. The hardest part will be getting the length correct. If you already have the mast in the up position, you can attach the baby stays and leave a little slack in them (not much). That should give you the correct length.
I used to have a balboa 26 that used a similar mast raising system. On that boat, I made "baby stays" out of nylon ratchet tie-down straps. It worked very well and had the added advantage that it was very easy to readjust the length if I got it wrong.
