Broken anchor windlass switch...
Aug 23, 2014
164
Catalina 310 Guntersville, Alabama
The red plastic knob came off in my hand when trying to pull it out to the off position. It seems the bolt is stripped and the nut will not hold. The switch still works but I hate to replace the whole thing. I tried to super glue the knob in place but did not hold past 2-3 times. Any ideas other than using pliers everytime I need to use the windlass? Thanks.
Feb 20, 2011
8,062
Got photos?
Think the mechanism could handle the torque of a die to chase or cut new threads?
Aug 23, 2014
164
I will take a closer look this weekend. The bolt is very short so there is not a lot of room to work. Thanks for the idea.
Mar 10, 2015
62
Catalina 30 Moss Landing, CA
Super glue works only with a tight surface-to-surface bond. I think there's a good chance that, after cleaning the threads of shaft and knob with acetone, two-part epoxy would do the job, as the threads would give an excellent grip with voids filled.
Aug 23, 2014
164
Nothing so far has worked well. I need to replace the switch. Right now I am operating by the old salty trick of a pair of vice grips!
Oct 26, 2010
2,216
Hunter 40.5 Beaufort, SC
Not sure of the length of the shaft but could you drill a small hole in the knob and through the shaft then press fit a pin into the hole? They have small pins that are designed for a compression fit like this. You can also cut the head off of a small stainless steel brad and use it as the pin with it super glued in to keep it from slipping out. I used this to fix my autopilot one time. If you want to get really fancy, you might try drilling a small hole in the knob that goes over the shaft, tap the hole to accept a small set screw and then use that. Just some thoughts.
Aug 23, 2014
164
Thanks for the ideas. If the threaded bolt that connects the knob was longer I could fashion a new knob from a piece of metal but it is very short. I can just get the vice grips to bite the end to pull and push the breaker.
