Broke my mast foot
84
Hunter 240 Branched Oak Lake, NE
While lowering my mast yesterday for winter storage, the mast foot of my 240 snapped where the pin is inserted. I see the part to order in the Hunter parts store, but I'm wondering if anybody can help me with a couple of questions. Am I correct that the mast foot is riveted to the mast itself? If so, how do you get the old foot off? I fear that I may be in over my head trying to do this repair myself; wondering if it's better to take the boat to my nearest Hunter dealer/shop in Kansas City. Any advice would be appreciated.
-na -NA Anywhere USA
To remove the pop rivets like any other rivets, you will need to drill them out. Use a drill bit the same size of the standard pop rivet. I think it is 3/16 inch but you will want to check what the standard size is. It could be a stainless steel pop rivet but if not, it is aluminum. Make sure you use a good bit. When off, take a file to the inside of the mast and file any old shards off.
crazy dave
Mar 27, 2010
84
Thank you, Dave. I've never done any riveting before, so it seemed a bit daunting at first. I've found a friend who knows what he's doing and can help. Whew!
I can remember the very first time I drilled a hole into a hull and was very cautious. Now it is a piece of cake and when I drilled too large a hole, I would reglass the bottom of the boat.
Try working on N scale model railroading steam engines taking every driver and gear apart and then also installing decoders. That is a challenge but I know how but oh do I wish for better sight and steadier hands as being an old fart in age and many other ways as well which Jim Seamons would also agree.
crazy dave condon
