Brochure and info on 76 Hunter 25
Don R. Bradshaw
I am purchasing a 1976 Hunter 25. I would appreciate any information on the older Hunter 25's. Also any recommended upgrades. Water System, Electrical, etc.
John Larsen
1978 Hunter 25
I have a 1978 Hunter 25 and found literature scarce. What I did find was not helpful. This site is extremely helpful. I was able to get more information by talking with other sailors in the dock and sharing some experiences. Each year I add an extra feature to the boat, like marine radio for Lake Superior (absolutely required), ship to shore power, circuit breakers, new wiring where required, bilge pump, replacement grey water drains, etc.
John Allison
I can help!
Don, I have the factory manual (zerox copy provided by Hunter) which I can zerox and send to you. It is comprehensive and helpful. Will send you a copy if you can provide me with your address. Also can provide you with a list of upgrades/mods which I have accomplished. Some of these include: running of halyards back to cockpit; adding a winch to the cabin roof for use with the halyards; changing the main sheet traveler which was positioned with stops to a traveler position controled with lines/pulleys; cutting a hole in the fuel tank ledge of the aft lazaret to facilitate getting at both the outboard bracket bolts (had to replace bracket) and cockpit drain hoze which also had to be replaced; adding a third separate halyard for spinnaker; added a permanently mounted gusher bilge pump. Electronics include: VHF; GPS; Loran-C; knot meter; depth finder; wind speed/temp gauge. Enjoy your 25, they are great pocket cruisers and surprisingly hold their own in local races. Also check the owners comments on this web site for sailing commentary as well as changes, etc.
Don R. Bradshaw
REQUEST FOR INFO ON HUNTER 25
TO JOHN ALLISON I WOULD APPRECIATE A COPY OF THE OWNERS MANUAL. TO DON R. BRADSHAW P.O. BOX 7415 NORTH BRUNSWICK, NEW JERSEY 08902
Jon Bastien
H25 manual request
John, I'd like a copy of your manual as well; I'd prefer not to post my address in the forum. Is there an E-address where I can send my request? Or, would you prefer to fax it? I have an (877) number you could use for that. Thank you, --Jon Bastien H25 'Adagio' H23 '2 Sheets to the Wind' jonbastien@yahoo.com
joel s bremer
70's? wha'd ya pay?
I've got a 1974 hunter 25, its apretty old boat but its holding up. My partner and I just put a new mast on it but were thinking about moving up to a bigger boat, curious, what did you find fair?
