Bristol 35.5 (1979) engine mount help
Mar 17, 2020
4
Catalina 25 Ithaca
I am seeking some guidance locating the proper engine mount part number or model (and hopefully a vendor) for motor mounts. Front mounts are visibly worn on my 1979 Bristol 35.5. The engine is a Yanmar 2QM20.
Are front and rear mounts the same? My web search has led to mixed results.
So far, Yanmar part number 124772-08441 for front and rear seems likely...
Thanks for any help...
- Scott
Feb 21, 2013
3,445
Hunter 46 Point Richmond, CA
Welcome to the forum!!
Front and rear motor mounts appear to be the same (Yanmar part reference number 124772-08341) according to the attached price list. Might shop around on-line or check with your local marine chandlery to find the best price.
4
Catalina 25 Ithaca
Thanks for the reply - I did order one of those from West Marine. The bolt holes lined up fine, and it seemed to be well made, but... it would make the engine about 1/2 higher than the original Yanmar mounts, even when the R&D mount was adjusted as low as it would go.
Likes: sail sfbay
