Hi all! I’ve posted on here once or twice because I am in the process of buying a boat, and I just made an offer on a Bristol 29! The offer depends on a couple of things, and while those are still getting sorted, I wanted to ask about this mast support that I spotted. It is a deck stepped mast, and under the wooden piece (head wall) that supports the cabin top there is a space about 6” from the floor to the keel. Under here is just a few pieces of wood supporting the load. There is a small crack in the fiberglass, showing that at one point the mast had caved into the support a bit. It seems as though the wood underneath is a perfectly fine support, but it didn’t look factory finished and I wanted to check on here to see if it raises any red flags for anyone.
Thanks!
Pete
Thanks!
Pete
