Right!!!!!
N'uff said!Well ... maybe there is another option. What about getting a much bigger boat and then move aboard and sell the condo?Go in partners with someone who has a boat and slip in a place without a bridge clearance problem?Renting or time share?Relocate?Keep dreaming and save all that money?There are some advantages to a smaller boat: Lower initial cost, lower maintenance cost, easier to raise the main. Shortening the rig will have a real negative effect on resale unless you find that one person who also needs a shorter rig. An older boat with a shorter aspect has the advantage of lower initial cost but you'll have to become really adept at maintenance (visit this site often!). Actually, if you own any boat you'll have to get good at maintenance but with an older boat one can expect more difficult problems. The good part about having a boat right where you live is you can work on it easier.Part of the joy of owning a boat can be working on it (okay, maybe I'm rationalizing a bit) and fixing her up. Check out the book "This Old Boat" (see link) to see what can be accompolished. You will need some tools and storage space for supplies.There are some really nice "pocket cruisers" that might have the mast clearance you need as well as the stability and interior accommodations. The downside is these tend to have more draft than what your local cruising area may afford. See link to "20 Small Sailboats to Take You Anywhere" http://shop.hunterowners.com/books/bookdetail.tpl?sku=90886
