We picked up a 1988 Bene 430 and the prop shaft decoupled from the transmission and damaged the shaft log on the inside of the boat where the seal is. Picture attached. I am told this is not an easy repair since the shaft log is embedded in the fiberglass of the hull and will need to be cut out and replaced with a fiberglass (G10?) log which most modern boats have. Has anyone heard of this type of repair? I am thinking of either cutting/drilling out the entire brass log or just cutting out the 6-8 inches from inside the boat and just glassing in a FG section that butts up against the existing brass one and extending into the seal area. Thoughts, tips, tricks?
