bronze vs. brass
I did not read your previous post, so I may be off base here, but I noticed you were talking about bronze with brass in ( ). Bronze and brass are two different metals and will cause each other to corrode as any two dissimilar metals will if you use them together. Your nuts and bolts need to be the same metal. More importantly, when you do plumbing, make sure you don't mix metals. For example, using a brass fitting on a bronze ball valve will cause corrosion. Getting back to what you mentioned in your question, I lean more towards stainless steel fasteners as long as I am not mixing metals, especially when strength is an issue.
