Recently installed a new water water heater and I used brass pipe fittings in the freshwater plumbing because that's all they had in the nearby hardware store. They did not have the plastic fittings I need.Please see the attached picture.
I'm running brass pipe fittings to reinforced PVC. The previous plumbing used plastic fittings to reinforced pvc. So the questions are:
A) Are the brass fittings non toxic? They said that they were less than 0.25% lead on the wetted surface area and did not have a warning about not being used for potable water.
B) Does anyone see anything wrong with the way I have this thing plumbed? Is the reinforced PVC going to present a problem in regards to temperature?
Thanks!
Thanks!
