Just Installed a Flagship!
Less than 2 months ago I installed a Flagship unit in my Catalina 30. We had been searching for a unit and considering prices for the size unit we were needing (Florida Panhandle) and had established a dialog via E-mail with several companies. Flagship's representitive informed us that they would soon (probably about now) be getting a LOT of units in because they had just gotten the contract to swap out the units in a large fleet of Coast Guard boats. Some of the units to be replaced were less than a year old. As luck would have it, he had just swapped out a unit for a sailor when I last contacted him. The owner had been very pleased with the unit, but it wasn't big enough for the boat he had. Don't know the size, but he replaced it with TWO units! Anyhow, the unit he had gotten back was a 16,500 with a resistive heater unit (not reverse cycle). The unit had been completely gone over, bench tested and the compressor replaced. The old one wasn't bad, but they felt that replacing it would be about the same as putting out a new unit. The unit came with a complete installation kit, including thru-hulls, strainers, filters, valves, hoses, pumps, vent hoses, vent covers, intake vent and air filter, thermostat wires and the programmable thermostat. All I needed to provide for the installation was the main supply wire. Every time I needed to talk to someone, I got a person on the phone. Every time I needed a recommendation or explanation, they were ready to help. I ordered the unit one day, and two days later the truck dropped it off. It took me a full weekend to do the installation, but I was working by myself. Of course, as soon as I got the unit installed, the temperature dropped so I really haven't been able to give it one of the 100 degree, 100 percent humidity day tests, but I have no doubt that the size is more than enough for our boat. I CAN say that the heater is great! We have had nights where the temperature has gone to the lower 30's and we have been toasty warm inside. If you would like to see the pictures of the installation, go to FTP://FTP.Sailnet.com and go to the Catalina 30 subdirectory and then to the Double Dutch folder, and under that, the AC Install folder. The unit was mounted in the area under the V-berth with two vents in the main cabin and one in the V-berth. The thermostat was mounted in the galley island in the main cabin, and the water supply was tapped off the flushing water supply for the head. With all the cutting, routing and general intrusion of a very large chunk of equipment, my wife only lost 8 inches of one small drawer of storage space. The unit is put together with equipment that should be readily available anywhere. For example, the thermostat is provided, but if you didn't like their unit, you could replace it with any three-wire thermostat currently available. There are no mystical computer control boards to fail that are only available from the manufacturer... all the electrical components are stock items at most electrical distributors. They use Cool Cube pumps and Groco strainers, bronze through hulls and valves, and the vent tubing is standard 4" boat vent tube. They have top and side discharge units to fit your installation restrictions, and the units are mounted on heavy (believe me, I had to cut a corner off and it took some!) stainless steel base plates. The only thing I had to do out of the ordinary was to put in a small automatic bilge pump under the unit because the area it is mounted isn't well drained. Because of the incredibly high humidity in our area of the gulf, the unit sweats and the drain is necessary. Under normal conditions, I doubt that you would need to go to that length.I would strongly recommend working with Flagship. They have a quality product, a good, knowledgable staff, and a business ethic that is refreshing in today's marketplace.Good Luck!Scott HerrickS/V Double Dutch
