Brand New Tohatsu 8hp Outboard Break-in
19
MacGregor 26S Annapolis, MD
Hi All,
I just upgraded from a '90 Johnson 2 stroke 8hp outboard to a 8hp Tohatsu 4 stroke. It was delivered with no engine oil and so I went to my handy dandy WM and got synthetic engine oil, with the correct specs, but then I read something on Tohatsu's website about using their own motor oil. Is this something I should pay attention to, or is it just another ploy to sell me more Tohatsu product???
Also, a guy at WM suggested that some 4 stroke engines require a little engine oil in the gas during the break in period, is this right? I didn't think you're supposed to mix oil into the gas of a 4 stroke engine.
Thanks in advance for any info you can share!
Sean
Sumner
Jan 31, 2009
5,254
I just bought motor oil and can't remember reading anything in the manual about having to use theirs, but I had a lot going on at the time so might of missed it.
I've built a couple car engines and most people that build car engines recommend not using synthetic for the break-in period, but that wasn't for a new car so not sure what they tell you to do now for a new vehicle. Maybe that is 'old school' and doesn't apply anymore.
You will like the engine though, I'm pretty sure of that :). We love our 9.8, which is the same engine,
Sum
Our Endeavour 37
Our Trips to Utah, Idaho, Canada, Florida
Our MacGregor S Pages
Mac-Venture Links
Jun 6, 2007
19
Thanks Sumner. I wanted to make sure I break it in properly and I know that once you go synth you have continue to use synth, so I wanted to see if anyone had any experience with this. For the rebuilt engine, did they say why you shouldn't use synth during the break in?
I'm glad to hear how much you love yours, it was a tough decision between all the different manufacturers. I just got it and it seems pretty big compared to my Johnson, I was a little afraid of having trouble fitting it in the transom area. Did you clamp it there, or did you get a motor mount?
By the way, I looked at your Mac S page and I loved your upgrades, I may have to use a couple of your ideas. :) Loved the little fold out table design! And the head, wow...I've always wondered what I could do to make the boat more functional down below and moving the head seems to be the best solution. How long did it take you to do that and the extended birth?
May 4, 2005
4,062
I would never recommend putting motor oil in the gas.
You could put 2 stroke oil in the gas (synthetic 2 stroke preferable (amsoil) ( or some marvel mystery oil)).
you have 2 things breaking in. the pistons/crank, and the gear case.
I would drop both oils after around 10-20 hrs... just to get any metal out...
and of course vary the RPM's...
Sumner
Jan 31, 2009
5,254
The common explanation given for using a non-synthetic for break in is that it is 'too slippery' and doesn't let the rings seat sometimes and other parts also have to wear a little initially to obtain a proper mating surface. Now that being said I don't know Tohatsu's feeling about that or what car manufactures recommend now for new cars. Parts are now made to a lot higher tolerances than they use to be and fuel injection cuts down of a lot of wear that took place with carbs that ran rich in the morning and washed the oil off of the cylinder walls. If you start with synthetic I'll bet you are fine, but also I see no harm at all running a good non-synthetic through the motor until the first oil change and it should happen sooner than subsequent ones.
Yep we love the table. Moves to about....
....any place in the cabin and is easy to....
... store out of the way, which is nice as the cabin is so small....
http://purplesagetradingpost.com/sumner/macgregor/inside-19.html
You know I've done so much I really can't remember how long the head took or the v-berth extension. If I had to guess I'd say 25-40 hours total for the basic install including stain and urethane. That wouldn't count the added ....
... shelving around the V-berth or the food....
....storage. The v-berth extension is fast and easy. The head you want to take time to get a good fit on the container for the Double Doodie bags so that it can't move and the lid seals good. Do that and it is a great system. Very few boats, even big ones can go out for more than a month without having to service the head unless they are out past the 3 mile and discharging.
The boat is very functional now and even after 7+ weeks on her this spring we really hated to get off,
Sum
Our Endeavour 37
Mac-Venture Links
Dec 8, 2007
303
-mac 26M -26M tucson-san carlos mx
tohutsu,mercury,johnson, or yamaha none of them make their own oil, it is all purchased from the same 2 or 3 huge motor oil blenders and bottled in branded containers.any marine rated four-stroke oil will do the job nicely.
Jun 6, 2007
19
Thanks Mr Bill, yeah i meant 2 cycle oil in the gas..I just didn't think you were supposed to do that. And you're right, the manual has a strict break in process as far as throttling, but not much on how soon to change out the oil, so thanks for that heads-up!
Thanks Sumner, I love the detail you put into your mod pages, the pictures really help! I didn't get much past your mods to see how you mounted your outboard, did you use a motor mount, or did it fit in the transom well?
Thanks Ray, that makes sense. So do you guys think using synthetic motor oil will benefit the motor in the long run?
-Sean
Sumner
Jan 31, 2009
5,254
-Sean
I agree with Bill's recommendations 100% :) and wouldn't add any oil to the gas.
Here is the stuff on how I mounted the outboard and why we bought the extra long shaft, which is why we got the 9.8 vs. the 8 since you can only get the long shaft on the 8. I don't think the extra 1.8 HP is anything to write home about, but wanted the extra long shaft...
http://purplesagetradingpost.com/sumner/macgregor2/outside-25.html
....good luck,
Sum
Our Endeavour 37
Mac-Venture Links
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
No synthetic untill the engine has at least 10 hours.
FC-W Four-Stroke Oil Certification Program
With the widespread introduction of the four-stroke outboard engine technology, NMMA considered it necessary to develop a marine engine oil category specifically for marine four-stroke engines. With all of the major outboard engine manufacturers producing four-stroke outboards to further reduce emissions and increase fuel economy, the need for oil specifically designed for the unique marine environment became necessary.
Working with the NMMA, industry leaders in lubrication technology developed testing criteria for this marine four-stroke oil. These criteria include bench tests for viscosity, corrosion, filter plugging, foaming and aeration. In addition, the oil must successfully pass a 100-hour general performance engine test.
Once an oil has been tested by a sanctioned test laboratory, NMMA will issue a license for the oil’s formulation and registers approved brands.
FC-W® lubricants have demonstrated the necessary performance and quality needed need in today’s high performance four-stroke marine engines. The next time you are purchasing four-stroke oil for your marine engine, look for the FC-W® trademark.
For more information regarding oil certification, contact:
Tom Marhevko
Vice President, Engineering Standards
312.946.6213
2011 FC-W® Registered four-stroke-cycle Marine Oils List
FB-00511J
Yamalube Marine Performance 4M Four Stroke FC-W 10w-30
Yamaha
FB-00512J
Yamalube Marine Performance 4M Four Stroke FC-W 20w-40
Yamaha
FB-00603J
Neptuna Speeder 10w-30
TOTAL Lubrifiants
FB-00604J
West Marine Premium 4-Cycle Outboard Oil 10W-40
West Marine
FB-00605J
Mallory 4-Stroke Motor Oil 10W-40
Lubrication Technologies
FB-00606J
Mallory 4-Stroke Motor Oil 25W-40
FB-00607J
Quicksilver Synthetic Blend 25W40
Mecury Marine
FB-00608J
Quicksilver 25W40
Mercury Marine
FB-00610J
Mercury Precision Lubricants Verado 25W50
Mercury Marine
FB-00611J
Mercury Precision Lubricants Synthetic Blend 25W40
Mercury Marine
FB-00612J
Mercury Precision Lubricants 25W40
Mercury Marine
FB-00613J
Mercury Precision Lubricants 10W30
Mercury Marine
FB-00616J
Lubrax Nautica Tecno SAE 25W-40
Petrobras
FB-00617J
Mystik JT-4 Synthetic FC-W 10W-40
CITGO
FB-00618K
Mystik JT-4 Synthetic FC-W PWC 10W-40
CITGO
FB-00619K
Kawasaki Jet Ski Watercraft 4-Stroke 10W-40
Kawasaki
FB-00620K
Yamalube 5W30 Full Syn Marine FCW
Yamaha
FB-00622K
Mallory Marine Semi Synthetic 25w40
FB-00623K
Quicksilver 25W50
Mercury Marine
FB-12450L
Yamalube Marine 4 FC-W 10W-30 for Asia/Pacific
Yamaha Motor Company, Ltd.
FB-20110B
Pro Star 4 Stroke 25w40 Outboard Oil
Kinpak
FB-20112B
Pro Star 4 Stroke 10w30 Outboard Oil
Kinpak
FB-20113K
Pro Star 4 Stroke 10w40 Outboard Oil
Kinpak
FB-20333H
Prosurf 4T FC-W, SAE 10W-40
IGOL France
FB-20444H
Prosurf 4T FC-W, SAE 10W-30
IGOL France
FB-20555H
Prosurf 4T FC-W, SAE 25W-40
IGOL France
FB-23656K
MOTUL Outboard Tech 4T 10W-40
MOTUL
FB-30011B
Amsoil Formula 4-stroke Marine Synthetic 10W30
Amsoil
FB-30012K
Amsoil Formula 4-stroke Marine Synthetic 10W40
Amsoil
FB-30018B
Shell Nautilus 4T Outboard Motor Oil
Shell Oil Products US
FB-30025B
Pennzoil Marine Premium Outboard 4-Cycle 10W-30
FB-30220H
SUPRA 4
Eduardono SA
FB-31000B
Nissan Marine Premium Four-Stroke Oil
Tohatsu America
FB-31001B
Tohatsu Premium Four-Stroke Oil
Tohatsu America
FB-40003A
Ravenol Outboardoel 4T
Ravensberger Schmierstoffvertrieb
FB-44220L
Racing Oil 4 Tiempos
Comercial Importadora S.A. de C.V.
FB-44228K
Honda Marine Engine Oil 10w/30
Idemitsu Lubricants
FB-44303J
Gulf Pride 4004, SAE 10w-40
Gulf Oil International
FB-63311K
MOTUL Outboard Tech 4T 10W-30
MOTUL
FB-80114J
West Marine Premium 4-Cycle Outboard Oil 10W-30
West Marine
FB-80116J
West Marine Premium 4-Cycle Outboard Oil 25W-40
West Marine
FB-80812K
Ravenol Outboardoel 4T 25W-40
FB-80813K
Ravenol Marineoil 25W-40 Mineral
FB-80814K
Nautic 4 Tiempos SAE 10W-30
Commercial Roshfrans
FB-80815K
Nautic 4 Tiempos SAE 25W-40
FB-83138K
Ravenol Outboardoel 4T 15W-40
FB-83139K
Ravenol Outboardoel 4T 10W-40
FB-83140K
Ravenol Outboardoel 4T 10W-30
FB-84000K
CEPSA Fuera Borda 4T
CEPSA Lubricantes
FB-84113K
Suzuki Marine 4-Stroke Engine Oil 10W-40
MOTUL
FB-84224K
Suzuki Marine 4-Stroke Engine Oil 10W-30
MOTUL
Jun 6, 2007
19
Wow, thanks for all the info guys, this really helps!
Can't wait to give her a shot. I imagine it'll be a nice upgrade from old Johnson.
Jun 6, 2007
19
Hi All,
So here's the latest...it took a while, but I've got the motor mounted and was just about to start her up and go through my break in processes. As I lowered my Mac into the ramp, I noticed a substantial amount of oil, to the point of a little oil slick around the boat. It looked like it was coming out around the prop. This is a brand new 8hp. One concern I've had has been, the motor came with a factory to dealer checklist that had no checks or signatures on it, so i was a little worried to start her up. That said, I figure the oil can just be residue from factory tests, but wanted to check with you folks before moving forward. Also have to contact the dealer, but wanted to get my ducks in a row, before I contacted them. Let me know what you think..
Thanks!
Sean
May 4, 2005
4,062
Sounds like the Lower unit case... but could be nothing.
-you verified that it does in fact have oil in the LU and block? (they don't usually ship w/oil)
If you put it in the water, and ran it even for a short period, you can drop the gear oil, and look for any water. (milky color).
there's (typcially) 2 seals. one from the prop side, (large screw in 'plug' w/ and O ring behind it, and from the top, water pump O ring. and of course the 2 screws in the side for adding/dropping oil.
maybe you should just run it in a trash can for the 1st 2 min...
I would suggest you buying the specific factory repair manual, which normally requires the serial number. my merc was ~$45.
walt
Jun 1, 2007
3,535
Hope everything works out, I’ve enjoyed almost the same outboard.
Maybe not related or useful in this case but I’ve had sort of a similar experience.
On two different small outboards that I have owned, if I leave the outboard laying down and the prop is supporting part of the load (for example, the outboard is layed on a flat surface and the prop is contacting the flat surface), I will have oil leak out at the prop.
On both of these outboards, if I never put any sort of pressure on the prop itself, I don’t get any oil leakage. Even after having the oil leak problem, if I keep any pressure off the prop, I have no more oil leakage. For example, if I keep both of these outboards on the back of a boat where the prop is not supporting anything - never any issue..
Both outboards manuals seem to imply that you can lay them down (on the correct side) but if I do this, I make sure the prop itself is not at all taking any of the load.
Jun 6, 2007
19
Thanks for the good info.
Mr. Bill- I assumed the LU had oil already in there, the only oil I added was for the block, maybe best not to ass-u-me... :) I'll check this weekend and get back to you. I'm hoping it's nothing at all, just nervous about starting her up and possibly causing damage.
Walt- That's a good point. I did have it laying down when I drove it to the boat, resting with the prop down. I'll press on the prop with a little force and see what I notice.
Either way, I'm starting her up this weekend! Not enough weekends left to be stuck on land...
