Mounting bracket
There's a lot of things you could mount there, but I have always assumed that it is intended as a small winch mounting plate in case you want to add a winch for the outhaul or reefing lines, or even a cunningham. I haven't done this but I've been thinking about it. It would make adjusting the outhaul a lot easier.Tom Maduras/v Good Vicesp.s. I also use it as an attachment point for the lifting line when I take the mast down each winter.
