The "hub" or gearbox installed in my Hunter 41DS needs replacement. It is a Lewmar 140TT part # 581001. I am wondering if it would be possible to dam up the starboard side of the tunnel, and then tip the boat over with the halyard enough to get the port end of the tunnel out of the water. The tunnel is located just below the water line so the boat would only have to be "tipped" up on the port side maybe 10-12".I am thinking of doing this while the boat is at a dock, using a dock piling as an anchor for the halyard. I am still in the thinking stage, any thoughts would be appreciated.
