Box: Large or Small?
Joe O
I'm planning to add a Cold Machine to my H34. I have an 8 cu ft box and I see that the small box would be ample for 8 cu ft. But I like the larger size box (more freezing capacity). Would there be any power comsumption differences if I went with the bigger box?
Bill Thomas
larger bin
The larger unit will also work. When the box size is on that fine line between the 2 different evaps, go with the larger one if it will fit. The unit will about 1 amp more, but should run less. There wouldn't be any more appreciable current draw.
JoeO
Thanks Bill!
I'll go with the bigger box then. Thanks for your help. Joe
