OK everyone, here's some stuff I learned while
rebuilding all four of my Bomar hatches. First, the sealant used is silicone. Use nothing else. Ask anyone in the business. And no one knows the half life of silicone. The first silicone ever made is still intact. It doesn't break down in sunlight. Note that I didn't say the bonds formed are still intact, or that the stuff didn't burn up when an engine gasket got too hot. But if you follow the instruction on the tube and the instructions from the hatch manufacturer, it'll stick for at least a lifetime. The proof is in the conversation we are having here. It is centered around how to pry the lens away from the frame. After that's done try some of this stuff to get rid of the old silicone. http://www.amtexchemical.com/pages/1/page1.html?refresh=1067351487284 The link is a couple years old now and I haven't tried the stuff. I did it the hard way. As far as painting goes, I ordered up Awlgrip and then sent it back. I found a better way. I had mine powder coated. The shop even does the sand blasting needed to insure adhesion. The whole process cost less than the paint in the can. All the work I did to prep my hatches was not necessary. I just had to remove the lenses and take them apart. (hardware too) Then they look like this. The finish is good for at least 20 years. Kinda like silicone. Oh, be sure to order the correct gasket from Bomar. They are not all the same. It makes a difference when dogging them down. I have to change a couple of mine.
