Bow thruster
  • Thread starter Dan Hawryschuk, S/V Floridays
  • Start date
Drew Dolak
We love our thruster
We have a Vetus Bow3512, I think, on our Passage 450. I thought hard before having the dealer install this $8000 option, but have never regreted it. Yes, it's a sailboat; yes, we all should have the requisite skills before taking to the water, and yes it is expensive to install and operate. 1. We only use it when the engine is running, so there is no wear and tear on the batteries. 2. It *may* effect sailing performance, but let's acknowledge that the Passage 450 is a floating Winnebago. Windage on this vessel is difficult to underestimate. 3. When the skipper is at the helm and I as first mate am handling the lines, I want all the control possible to be in my wife's hands. 4. Several times we have pushed the bow onto a sandbar and with the engine in reverse and the bow thruster *ounching* (this is the skipper's description of her technique) we have come free. 5. Backing a 14'-0" beam vessel into a 15'-0" slip is a matter of aligning the stern, having the engine in reverse idle and using the bow thruster to move the bow, and hence the stern, port and starboard for precise alignment with tne slip. Every time the skipper has put this 45" vessel exactly up to a dock she has received congradulations. Until they find out we have a bow thruster. Then they say that we "cheat," "have it too easy," and so forth. We just smile. It's supposed to easy, right? I've attached the Vetus website. Good luck.
C
charles
cheap thruster
i think that most of the people who are inspired to install a bow thruster make the decision because of one or two docking "incidents". after a hard day of sailing and drinking, it's just a pain to get that pig back in the slip. i don't know if you have done so, but replacing the standard two bladed prop with a three blade greatly improves responsiveness, stopping power, and backing ability. you may want to try this, $350 for my 45, before you drop the really big bucks to compromise your hull integrity.
Phil
TIDEWATER and LEWMAR
Tidewater is an excellent option. You should look at the Lewmar TT series. I understand that Hunter have moved to them for the new 44, which is a 42 hull right?
