This could be a sign that the motor is on its way out. The enamel coating on the motor windings will melt when the motor gets too hot and will then draw more current moving forward. Hopefully a PO just put in the wrong size fuse. If you know the model of bow thruster, you can find out the current draw. Looking at the size of wiring going to the motor is also an excellent way to help determine fuse size.
