Reconsider
your choice of new anchor - particularly since it's a cheap copy of the genuine Bruce.Here's what Bruce used to say about the issue:"At first glance the genuine Bruce anchor and the look-alikes that have flooded the market appear to be the same anchor. Close inspection will reveal that the look-alike is different in a number of disturbing ways. If you line up a row of the look-alikes you will find further disturbing features: whereas the genuine Bruce anchor has the same geometry throughout the anchor range, the look-alikes have shank angles that vary widely throughout the anchor range and even between same-size look-alikes..."Would you leap from a plane with a haversack on your back because it looks like the real thing and comes at a rock bottom price? Remember an anchor is a safety device upon which the survival of you and your boat may ultimately depend."And here's what West Marine say about the Claw:"Failed to set during this test. Maximum tension under 700lb., briefly."SAIL:"The Claw is Lewmar’s version of the popular Bruce anchor that cruisers have been using for years. It stows easily in a bow roller, its one-piece construction is super-strong, and it is reportedly designed to be effective in a variety of seabeds. However, our test results came as a bit of a surprise: The maximum load we recorded for this anchor with 5:1 scope was 886 pounds. And that was only a short spike before the anchor released completely. During most of the 5:1 pulls, it seemed to set and release rapidly without ever really catching. One pull showed it was slowly dragging under a load of about 300 pounds, but we were never able to say with certainty that the anchor had set. We recorded similar results with 7:1 scope. One idea we considered was that the Claw’s flukes were simply not sharp enough to penetrate the harder claylike sand.The beach pull was also telling in that the Claw dug a much longer trench than other anchors that produced better results during the holding-power pulls."What's your boat worth to you?
