Jeff do you know the reason for putting the drum
below deck level? They looked kinda neat when they first were produced, but, why? I would think that sail area can't be the reason. The headstay has to move rearward so the luff loses the area gained closer to the deck. It can't be simpler to produce, what with the extra deck hole for the headstay/foil and the complication of leading the furling line rearward under the deck and having it then made available to the crew in the cockpit. All of that doesn't even take into account the reason this tread is running, The messed up anchor roller/system. I don't get it. Mayby I'm old school,,,P.S. I see what looks like an exit block on your deck, but again, why?
