I replaced the bow light on my 86 Hunter 31' because the old one was not working. Then found new one does not work either. I get batt voltage at the panel, but not at the connection in the port side of V-berth where the wires exit the cabin, through the deck to the pulpit. Jumpered from the panel to connection and the light works. Obviously I have a problem somewhere in the wire between the panel and the connection that exits the cabin [surprisingly and thankfully, the wire that goes through the pulpit to the light is not grounding]. My question is whether my problem wire runs on the port or starboard side of the boat. It would have to be an independent wire since it has its own circuit, but not sure if I can just attach a new wire at one and it pull it through using the old wire as a fishtape.
