My C30 has the original Aqua Signal 25 bow light which needs to be replaced.
I chose to go with and ordered the MarineBeam USCG approved LED bow light which is rated for 2NM.
Didn't consider that it was larger and won't fit the existing pulpit mounting plate. I can make an adapter plate out of starboard but......
The issue is the wiring. The MB light is sealed with 8' of wire out the back. I'll need to cut it and use shrink adhesive butt connectors to connect to the wires coming out of the pulpit rail, leaving them exposed to weather. I thought maybe I could coat them with 3M 4000UV to protect them. The hole in the rail is too small to tuck the connectors into it.
The alternative is to just replace with a new Aqua Signal 25 which is rated for 1NM. The AS light is made so the wires connect inside the light.
Thoughts? Suggestions?
