If you do it, do it right!
If you are going to barrier coat your hull it only makes sense to repair the blisters now. Do it right. You must ensure that all blisters are completely opened up and drained and rinsed. It is also very important to ensure the hull is dried down to optimum moisture content of about 13% before doing any filling. If not, the blisters will come back. Plan to have the boat on the hard for at least three months. You may want to have the hull blasted, but doing the blister repair and subsequent barrier coat is easy for an amature as long as you don't mind working with epoxies, and follow the manufacturers instructions closely. My first boat was an old '70 Catalina. I got her for a deeply discounted price because the boat had faily estensive blistering (sever hundred but all under the size of a silver dollar). My son and I took it on as a project. It took us collectively 200 hrs to strip the hull down, repair the blisters, and barrier coat. We starrted in January and let the hull dry until May when we started the filling. We live in BC Canada so not a good time of year to do this, but we protected from the weather with poly and used a dehumidifier to draw moisture out. When we finished the bottom looked like a new boat, and 6 years later when I went to sell her, the bottom was still sound with only a handfull of blisters. As a result we made a bit of a profit on our endeavor which we put toward the purchase of our Hunter.Best wishes and good luck,Doug Margison,SV Mokum II
