Bottom prep
187
Hunter 33.5 Missouri
Thought I'd throw this out to everyone. Am in the process of having the bottom paint remove down to the gel coat. It is being done the traditional way, scraping and sanding. I looked at the options and stripping with chemicals wasn't practical. However I seriously considered having the bottom soda blasted. Would like to hear some feedback from those who have used it. I have some knowledge of this method but have never seen or talked to anyone who has used it. Several internet sites that offer some interesting information on this service. Steve
Barnacle Bill
Sandblasting versus sanding or scraping
Not a fun job, aye? You can blast your bottom with soda, black diamond, sand, etc., but your follow up work might be more, but that could be a good thing too. Not sure how old your boat is or if you have blisters, but if you blast your hull, this creates an opportunity to apply an epoxy barrier coat before applying antifouling. Blasting is quicker, but leaves behind more damage to the gelcoat that has to be faired and repaired, etc. For fairing use a VC product (now owned by Interlux) called Watertight, an epoxy fairing compound (2-part). It is easy to mix, apply and sand. But, as I wrote, you might as well apply an epoxy bottom and I recommend Interlux's Interprotect system which includes 1000/1001 epoxy, then the Watertight fairing compound, then their 2000/2001 epoxy barrier coat and then your antifouling paint. Stick with the recommended number of coats, their procedure of application and pay attention to the temperature that you are applying the stuff in so that you can apply as much material as possible in as short a time as you can, but still give the product time to cure between coats, etc. They lay it all out for you. If you are going to sand or scrape, then you can still apply the epoxy barrier coat, but eliminate everything except the 2000/2001 epoxy before you apply your antifouling paint. If you only sand to the point where you smooth out your antifouling, but don't remove it all, you can then apply the antifouling, but don't put epoxy over a bottom that is not totally clean of antifouling.
Alan
4,174
Hunter 35.5 LI, NY
Peel-Away
It's safe, easy, cost effective. However, do not use the Home Depot stuff. Use the marine version, they are not the same!
fox
Feb 22, 2006
3
- - AL
paint removal
I just completed this job on my boat--I started out sanding and scrapping. After slow progress I got some Kleen Strip fiberglass paint remover and removed all the old bottom paint. This will not hurt the gel coat and or barrier coat. You can get this at Home Depot and or order it through some automotive stores (car quest). Just brush it on and let sit for a few minutes and scrape off. This stuff worked great and was much cheaper then peel away. I then sanded smooth, applied 6 coats of barrier, sanded orange peel off, and then applied 3 coats of VCoffshore. Big job and I thought it would never end.
Jun 3, 2004
80
- - Guilford, CT
Peel -Away
I did this to my 30, 2 years ago. I counted 13 layers of paint on top of my barrier coat. I used the home depot Peel Away 1 which worked fine but it will not cover as much as the marine version. That's the only difference. HD version goes on with a trowel, Marine version you can use a brush, they say. And you still have to sand here and there after you peel. There's a big thread on this in the archives, FYI
