Bottom Painting
Jul 16, 2020
2
Hunter 29.5 Garfield, AR
I am getting ready to paint the bottom of our Hunter 29.5. The last time it was painted was at least 8 years ago. What is the best epoxy, best primer and best paint to use. This boat has been kept in inland lakes most of it's life. Thank you. Capt. Walt
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
West Systems epoxy, Interlux barrier coat, and then whatever bottom paint yields the best results in your part of the world.
Regarding the epoxy, I'm no expert; maybe you'd want to match what the boat was made of? And re-do the gel coat where the blister repair is done?
Likes: Dalliance
-na -NA Anywhere USA
First the best anti fouling paint should be what is recommended for your area, period!
Secondly if stripping the keel, go to bare metal and first coat with a metal primer containing zinc chromate. Make sure you check the moisture content in the hull before applying any paint. If stripping all the way, apply 3-4 coats of a good quality barrier coatings.
Likes: sail sfbay
Jan 4, 2006
7,870
By epoxy, I presume you are referring to the barrier coat. I would recommend some heavy research on this item re hull dryness. If the hull is not dry to begin with, you may wind up exacerbating any blister problems you now have. And unfortunately, as much as I love lake water and detest salt water, anecdotally speaking, fresh water promotes blistering more than salt water. And osmotically speaking (if that's even possible o_O) it fits the theory of osmosis
What is the purpose of the primer ?
