I used the marina,,,, and found blisters!!!!
I ended up using the marina's lift. They charged $4.00 a foot to lift. My boat was put on blocks just high enough to let the keel down about 45-50 degrees. Probably a good thing i did that because once i got under the boat and started sanding the rough spots-- i found BLISTERS!!!! They were around the ballast valve and also around the centerboard area. Also had some on the centerboard too.. i did fix most of them but i was more concerned with the ones on the hull itself. I grinded them out with a dremal, let em dry a few days then then filled. They didnt seem too bad but i know if left untreated they would only get worse with time.Anyway-- all is said and done, shes lookin like brand new now, new stripes, new bottom paint and all shined up. I let her sit on the trailer for a week since the temp dropped below 60 the night after i painted. THis way the paint can cure up. I plan on launchin this weekend and head out sailin once again.I will try to post pics once i get film done.. i took before, during, and after pics.... alot of work but well worth it...
